The harmonic balancer took an 8" gear puller with a 2ft bar.
Well crap. The harmonic balancer wouldn't come off the rear shaft. Using the 3 bolts didn't work. One broke but enough stuck out that I got it.
I'm going to get a bigger puller tomorrow. Any specific snap ring pliers I should get while I'm at the store?
Trying to fix ignorant on my part. I read a few places to get good "lock ring" pliers instead of "snap ring" pliers. Is there a difference other than what some folks call them? Link to "good" ones vs "cheap" ones? I ask because I have this job in my future too.
Bought my valentine ( yes it’s my Jeep) A couple of gifts
I’ll take it out to dinner later haha
I’d hate to see you and your jeeps children![]()
They’d be short, flat faced, blue and always thirsty
So a Smurf with a drinking problem? Lol
Busy day of Jeep life. Since it’s gorgeous outside I skipped taking a nap (which I’ll regret at 4am when I’m getting off work) to work on my engine. I got the main bearings in and fitted the crankshaft. There is no lateral play that I can see and it spins really smoothly by hand so I’m pretty happy with that. I also got the camshaft lubed up and installed. It went in without a hitch as well. I was going to stop there but figured why not put the gears on for the timing setup then I wouldn’t have to worry about the camshaft sliding around and scratching something up. I got the timing set and put the new gasket and freshly painted cover on then I installed the new harmonic balancer. I made a good bit of progress today.
Got started on installing my sub...riv nuts, a dab of RTV and some neoprene washers. I depinned the high side connectors since I don't need them. I really should replace the cherry bomb and buy a bedrug to put over the bedliner...but just making the stereo louder feels right. Almost got done and got called into work...boss man wrecked his truck on the pass and needed me to cover a shift.
Mac, this is a little close up so I can't tell. Where are you installing this? I'd like to see more pics and info on the rest of your system.
I just followed the recipe others have posted. Rockville 400w sub. My only deviation might be installing it behind the passenger seat because I have a Tuffy drawer under my driver seat. That and most posts on this sub glossed over how they were mounted...I used riv nuts through the tub and RTV.
My biggest concern with the Rockville sub is it's lack of any waterproofing. I live in the PNW and it can get wet in the cab...I've had a solid half inch of water sloshing around from melted snow before I pulled the drain plugs.
That and when I pull the top come spring...
