Thanks very much for referring to both of these. The revision seems to just give more detail on the symptoms/conditions. The rest of it looks to be all the same.
I'm not in any rush to cut wiring. However, I do have the blinking CEL 15 seconds after a key turn without cranking the engine.
I'll continue to monitor and see how it goes.
Shipped my LJ from Hawaii to SoCal. Ran fine in Kona and Cal but wouldn’t pass smog check in Cal and had the blinking CEL. Took it to a dealer and they did the power module modification, no charge and without a fuss. Did have them purge brake system which wasn’t cheap. Passed Smog no problem after the mod. They did suggest I find a TJ specialist as they had no one with experience working on them.
Get lockers. You too could follow our mid-western farmhand friend. That dude is nucking futs.
I was cleaning caked on dirt and ran across these. Casting imperfections or cracks, or both. I've never had fluid dripping.
  • Wow
Reactions: RINC
How long has it been? The last couple of years have seen the influx of out of staters -congestion is significant now. I keep this picture to show what a traffic jam used to look like on my street…😁
my kids just bought a 1950’s 2br 1 bath starter home…300k in Meridian.
Lol been yL
eah
Well I grew up there, went to Meridian HS, (graduated in '86). We move to N, ID about 9 years ago at this point. In HS, I had to drive CLEAR out to 10 mile and go help my cousins buck hay. When I moved, we lived on Black Cat and I had to drive in a mile to go see those same cousins. ;-)
Reactions: JustDandee
Installed inner shift boot. Pretty much jacked up the shifter knob getting the insert out to reach the nut. Dremeled it a bit so it's at least smooth & usable.
Found out the plastic trim is a bit small since its not a stock console. So just put the old outer boot back in place for now. It's not torn, just old & sitting in there. Hafta rig up something to make the plastic trim catch in there somehow.
