That doesn't bother me in the least. There's lots of shit I don't know. But the shit I do know, I am 100% sure of. The difference between me and most folks is I have no problem saying when I don't know.
So long as you know i was joking with you.
The hiem joint link ends won't last long
What the hell is going on there?
They don't look like rod ends. They look like the crap joints that RK makes or made. It also has a Daystar body lift which needs to go away and then hunt down the idiot that can't build rear bumper tabs that actually center on the frame.
So long as you know i was joking with you.![]()
Those lower ones don't. The ones on top of the rear diff sure look small enough to be rod ends though
I could see that, I just didn't know that anyone was dumb enough to make a product that does that.
Haha, this is good stuff. Thanks guys. I originally picked it up for the property use instead of a side by side I was looking at that cost way too much. I figured it could do the job and be street legal in a pinch, so she won't see many pavement miles in a year. I work 2 miles from my rent house so it might get 30 miles a week tops until we move out to the property. At that point, it will be a beater.
I used to run Fox body Mustangs so knowing it is an 8.8 helps a lot.
I haven't had it out on the road at any speeds yet to know if the driveline vibs or if I am taking my life into my hands, lol.
At least you are taking in the spirit in which it it intended. The last guy we chatted with got all huffy and took his ball and went home.Haha, this is good stuff. Thanks guys.
I suspect that trying to get it up to highway speed will show you why you got it for the price you did. It is going to be a handful most likely and you won't want to spend too much time at those speeds until you fix up a few things.I haven't had it out on the road at any speeds yet to know if the driveline vibs or if I am taking my life into my hands, lol.
I got confirmation it is an 8.8 from the guy that made the diff cover, so good work guys. It should not present a problem to tear down.
