Congratulations. That has to be a great feeling.
Thanks.. it is.
I'm sure it's not as beastly as yours will be when you finish it.. I really like your intake setup. I like when people think outside the box.
Thanks.. it is.
And a thanks back at you. I did the stock look the first time around and wanted something more this time.
BTW F&B TB's sells a 6 pack for your Hemi also.... For that next big build.
This makes me want to put all my remaining mods on hold and do a Hemi swap. Nicely done.
Got the rest of the pieces yesterday to make my air intake.
It's 4" mandrel bent stainless steel tubing. Ought to breath ok..
I put the filter element just forward of the fan blast hoping it'll catch a little cooler air. I'll watch the IAT and see if I'll need to fab a heat shield for the filter.
I guess I'm the only one that liked the drier vent set up..
I really think you should talk to a guy with a 3d printer and mod that intake cover to read "Jeep Wrangler" instead of Dodge Magnum. It would be pretty easy to do...Grind the existing letters flat, import an image file of the font for Jeep Wrangler (those are all over the web for the sticker people) and then grow a base to match. Some High temp Epoxy and silver paint...you'd be all set!
Great Job by the way. It's cool to see someone do a "budget" hemi swap, working alone in their garage.
I definitely agree about the Dodge Magnum on the intake box. The 06 and later ones don't have that on them, only the HEMI part. To expensive to buy one just for that reason so I have given thought to grinding that off and either leaving it like that or buying "Jeep" emblems for a Grand Cherokee and using that. I like your idea of the 3D printed emblem. I might look into that and see what I can come up with.. Will the 3D printed plastics hold up to under hood heat? I don't know what the melting point is on the material. Yes, good idea because I don't like the Dodge part on the Jeep and will at the very least remove it at some point.
Also, I really like that you put "Budget" in quotes...
I guess budget doesn't always mean cheap, just within what was expected, right??
Before I went to the cowl intake, I did just that to the stock Hemi intake box. Ground off the old 5.7 Hemi logo, cleaned up the surface and painted it black, and added a 392 emblem. I thought it looked pretty cool, and wish I could have kept it on there.
I think yours only had the HEMI wordage on it, correct not the Dodge part?
I'm sure it would be somewhat expensive, but your build would be very cool with a "Shaker" air scoop from a Scat Pack Challenger. It would definitely go with the "392" theme and would keep IAT's down...
Don't know that I've seen any Wrangler's with that so it would be extra cool....
I know, something else to think about modding..
Not any performance things today, but I did change out all the old speakers for Kickers.
5 1/4 in the dash, 6 1/2 in the overhead and 6 3/4 sub woofer in the console. Head unit and amp still factory. Made a huge difference. Won't win any system contests, but nice improvement for the money and effort. I did put poly fil in all the enclosures which always helps on the low end.. I also had to add 2 screws to the side of the console above the sub woofer to keep it from buzzing real bad with the new sub.
I’ve been thinking about trimming the factory grill out of there. I’m running the same speaker, and I’m pretty sure the surround is hitting the plastic. I haven’t been able to find anything to replace it with, though, that also won’t interfere with the seatbelt.
