RE lifts have always sucked. Although 18 years ago people thought they were top of the heap on these forums
Back in the JU forum days. LOL.
Yes they are E rated Mats which I understand is overkill.
My guess is that you have RE1355 front and RE1360 rear and in my experience they typically net 5-5.5 inches of lift and have the rates to match. This is one time I will tell you that changing out springs for something like Rockjock will likely make a difference.
Ride quality. That RE lift sucks all the way around. It is 1-1.5 inches taller than 4 inches which is the generally accepted max height for short arms. The front spring rate is 35-40 pounds higher and the rear springs are 10-15 pounds higher than a majority of four inch springs on the market. And if the OP used the Rancho shocks that are typically recommended for four inches of lift the travel bias will be most likely be off as well.
I would think a C rated tire would be better. Why did you go with E rated? Yikes!
I'd love to do this. In fact I've called rockjock before. I suppose I'll have to get my driveshafts resized and possibly change my rear track bar though. Yes I measure about 5.5". As well as new shocks. Gonna be about $900 but I'm willing to do that for a better ride as I plan on taking this jeep cross country. This would also give it a much better stance.
What rear track bar are you running? Did you have the front shaft changed? I would not worry about shocks until you have got your desired ride height and see what the travel spit is with the shocks you have.
RE adjustable rear track bar with an RE track bar mount to level it out a bit. I do have an Adam's driveshaft in the front and Tom woods in the rear. (Rear I changed, front came with jeep.)
Should I outboard and have shocks valved? Should I buy a long arm kit?( Haha kidding) I've followed Nick's yellow jeep build thread and saw Mr Blaine outboarded his shock towers and valved fox shocks. Would that be my best option?
A picture of my dad in my TJ^
Anyways, I've owned my TJ for about four years now. I've been very meticulous with it and one thing I could never get right is the ride. I am currently running around a 4" short arm RE lift with the rancho 5000X shocks. This lift came with the TJ. I have the tires at 27psi. I daily drive my TJ and if I want to keep it for years to come I'd like to address this. My Jeep is light with a soft top and aluminum rear bumper.
Thank you for reading all of this!
I had the same issue. Tried four different shocks but the ride was always poor. Blaine outboarded my shocks and I’m super thankful for the improvement.
Haha yeah I'll be honest I wasn't aware of the importance of C rating at the time. Next set will definitely be C rated...
I'm waiting for the day somebody figures out how to swap a TJ body onto a modded UTV. With 24"+ of suspension travel in stock form, surely it could be interesting...
This is my situation right now, my LJR has e rated tires from 2011 and old man emu shocks. The amount of roughness is just unacceptable to me when going over bumps like railroad tracks, raised indentations, and potholes. It literally feels like a c rated tire would at 38 psi, except I'm using 28. First, I'm getting c rated tires and then if that doesn't do the trick new rancho rs5000x shocks all the way around. And by new I mean the ones that have been sitting on my shelf since the summer of 2020. They are for 2.5 inches lift and the OME lift I currently have is 2.5 inches, so should be a good fit but I'll find out when I cycle everything.I recently bought a second TJ. It came with E-rated 32” tires. Compared to my LJ driving the short wheelbase, close to stock TJ sucked. Bumpy, darty, etc. I played around with the air pressure all the way down to 20psi. It rode so bad, I gave up and swapped them out for C-rated tires, same brand with similar tread. Made a world of difference. Tires are your first suspension and also the easiest to tune. Get your tires sorted before diving into the rest of the suspension.
Cheers
Steve
