Hopefully you have somehow verified they know what they're doing so far as 42RLEs are concerned.Just got the phone call. Complete rebuild. Everything from relay packs to planetary gears removed and reinstalled….. $2800![]()
Probably too late, but I would have suggested you tell the installer to replace the vent lines.
Also, make them extra long so you can route them wherever you want.
Really hard to get to later.
The temperature of the ATF in the pan is the one that counts .I've installed temp sensors on both lines (return and supply) at the trans, connected to a 2-pole switch so I can see both temps before and after the coolers. Haven't run this setup in the summer yet, but so far the radiator and Derale coolers are reducing temps by about 40° at operating temps.
It's like having a thermometer in my house... I want to know the temperature where I am. I don't care about knowing the higher temperature of the air leaving the furnace or the cooler temperature of the return air.The pump draws from the pan to send through the cooling system. So the temp at the discharge of the pump and the ability to compare the temp at the return from the cooling process is irrelevant?
Appreciate it. I was just getting set to send you an email and order the pan.
Somehow I wound up with at least 1 extra Dorman pan, maybe 2.
I am 99% sure that I shipped all of them that were requested but the fact that I have an extra pan or two means someone is probably wondering where their pan is. Get in touch if so.
Again, and I can not stress this enough. It is impossible to track who gets and needs what when pans show up at random drop shipped from Amazon and similar. Then I get some with a name, but the name is not connected to the forum username. Then I get forum user names without real names.
At the end of it, I have a pile of pans. Then I have a list of real names. Then I have some forum names. If I have inadvertently screwed someone over by not getting their pan out to them, two things are true, I'm sorry, it was not intentional and I'm going to have to change how we do this.
So, who is missing a pan?
I have not received mine. I was planning to give it a month before checking in. I’ll follow up via our emails.
Back to the Rebuild. Picked up Jeep from shop and it drives like a dream. Almost could say throttle response is improved? IDK.
Problem is can’t drop it in to 1st gear manually. Also trouble hitting park in the sense that key can’t be removed without shifting down out of park and back in.
I called the shop, dropped it off and they said they will fix it.
But;
They also said they had trouble with it also but didn’t think to try shifting in to 1st. And that there is no adjustment in this cable and they know what to do to fix it and it’s just to “make it adjustable “
This scares me yet the jeep way a there and O typically trust this guy with about anything.
Anyone had this issue after remove/reinstall of a rebuilt 42RLE?
The cable is adjustable, they are being silly.
Shifter is where adjusted mine. Wasn't fully hitting park on occasion and would sometimes need to hit N to get it to start. All good now.That’s what I said. Adjustable on the tranny end? Not the shifter end right?
