So I'm trying to replace the Rubicon Express(?) front track bar with one from JKS. Only issue is that it looks like the Rubicon Express track bar uses an oversized bolt on the axle mount, while the JKS reuses the stock bolt.
Is it ok to use a stock sized bolt if the hole was drilled out to fit the Rubicon Express track bar? If not, can I simply drill out the metal sleeve so the oversized bolt fits?
