Too Good of a Deal on Snorkel? Also Jeep Rack?
IanConrey
Ellijay, GA
So I was doing some research on snorkels for my '99 4.0. All of them seemed to be in the $400-$600 range. However, I found this one (linked below) on Amazon for only $119. It only has 6 ratings, but they are very high. Anyone familiar with this product? Should I avoid this and go with a more expensive, well known, snorkel? Also, I'm wanting to get a Gobi or Garvin rack eventually, but I want to make sure the snorkel will still fit if I do. Anyone have experience on which snorkel/rack combos will fit on a TJ? All I've found online is Gobi racks with AEV snorkel kits, but they don't make them for TJ's.
https://www.amazon.com/dp/B091Y8MTB7/?tag=wranglerorg-20
Is this for actual use? Are you planning to fjord waters that exceed the lower portion of your headlights? That can't be good for your electrical system, which can often already be tenuous. Fjording waters of that depth can also be very dangerous if they are unknown or with current.
Yellow Submarine Dive GIF by Kev Lavery
Dogpile!
I actually run a snorkel on my Gladiator, with a Sy-Klone prefilter. IMO they have a purpose, I can drive it in the back of a convoy through the desert in the sand and silt all day and the air filter will be clean. And the diesel sounds are nice. I certainly didn't install it for water fording, although the JL/JT in stock form pulls air right off the surface of the front fender anyway, which just seems willfully stupid to me.
I don't run one on my TJ, it would just get ripped off on rocks and trees anyway. I don't see a need and I think they look kind of weird on a TJ, especially the styles like the one linked that run the intake lower to go higher first. Seems counterintuitive. I have, however, held one of those budget Amazon snorkels in my hand before. It's a lump of molded plastic, I'm sure it will work. It's just going to be on you to make sure it's all sealed up, and if you're actually planning on fording water that deep, that everything else is pretty water proofed too. If it's not sealed, you've made water intrusion easier and your fording depth lower because of the stupid down and up design. I don't recall but I wouldn't be surprised if it has a drain hole in the lowest part.
When I was young and more stupiderer my buddy had an XJ with a snorkel on it. We got it stuck in a quarry with the water up to the windshield, and it kept running. It was actually beneficial to keep the tires spinning at idle to help break the suction while we tugged it out with a tractor. That Jeep went on to live for another 150k miles before eventually subframe rot got it. The real solution is to just avoid water that deep, but truth is I have seen one work and be of benefit, when we were specifically seeking it out. I wouldn't voluntarily subject the electronics to water though. Shit, I try to keep the axle shafts above water anymore.
Reactions: reddvltj
Folks around these parts tend to get all squeamish over the thought of their tires touching some water…
Do you actually need a snorkel or do you just want the look? If you actually need it, here are some things to watch for.
  • The best snorkels are typically made of LLDPE, due to it’s strength and UV resistance.
  • Typically “LLDPE” or a symbol will be stamped somewhere on the snorkel itself. A rough, “grainy” texture, (NOT smooth/glossy) is also a dead giveaway that the material is LLDPE.
  • Keep in mind, with a hard enough hit, your LLDPE snorkel will crunch in your fender, whereas cheaper materials will just crack open. I’ve yet to see a snorkel material that will withstand moderate hits, yet yield before your fenders bend.
  • Another thing is you need to consider everything else that is exposed where a snorkel is actually needed. Do you know where your breathers for the axles, transmission and transfer case are? You need to get those extended up higher if you’re going to actually use your snorkel.
A snorkel does not give you the right to traverse the oceans or visit the Titanic. What a snorkel is, is cheap insurance, and there are many parts of the world where you can’t wheel without one. A $200 part to prevent a $3,000 engine replacement is absolutely a smart decision, but only if you wheel where it matters.
Reactions: SkylinesSuck
The stock intake is at the level of the top of the passenger headlight which works pretty well. Here's @Apparition in Moab a couple of weeks ago. No water was ingested.
20230611_082308_original-jpeg.435808
Also not as deep but a fun video on the same trip:
A Jeep ain’t no submarine 😂
