DuncLJ's Big Bolt-On Bonanza
How do you remove just the lower half of the door surround?
The lower has a pin that goes through the upper with a snap ring holding it together. I popped off the snap ring with a screwdriver (it is between the upper and the roll bar). Once that was off, it removed easily.
Reactions: MountaineerTom
Reactions: DuncLJ
Thanks. I had never really looked at how they were held together.
Reactions: DuncLJ
This is how I did it. I modified the lower part of the surround so I could remove it without removing the upper, and therefore without removing the top.
It's in my build thread starting on post #821.
https://wranglertjforum.com/threads/nashville-tjs-build-continued.42035/page-42
I'm going to use your quick disconnect idea when I put the door surround back on in the fall. I was able to get it off without removing the Rampage top, but it took some prying and fiddling back and forth to get it off.
I'd rather do it similar to how you did, and just pull a couple of pins. Thanks again for a cool idea.😎
Reactions: NashvilleTJ
Man I love this LJ. It is almost exactly what I want to do with mine once I save up the big boy bucks. So clean!
Reactions: DuncLJ
Thanks man! I appreciate it. I'm still saving up big boy bucks all the time, cuz it never ends. 🍻
So this chapter is being closed out.
The Jeep sold to another forum member, and is safe and sound in its new home in Texas.
Buyer is a good guy, I hope he has a great time with it.
I'll still be checking in around here. If I found the right TJ/LJ project, at the right time, I could be right back at it. 🍻
Jeep being loaded up on car carrier in CA...
New home in Texas...
I’m kicking myself for not buying this! 🙂
  • USA Proud
Reactions: DuncLJ
While I am taking a hiatus from Jeeping, I decided to undertake a new project.
I recently retired from the Military and Federal Govt. I rewarded myself with one of my dream cars.
I got myself a 1969 Corvette StingRay with a 427 and a 4 speed. I will leave it mostly stock, but will upgrade the steering, suspension and braking to more modern reliable standards. It is not meant to replace the Jeep, It is just another bucket on my list.
If I eventually make it back to another Jeep build, I would seriously like to explore a V8 engine swap. Possibly even in a CJ or a Jeepster Commando.
We'll See!
We'll See!
Congratulations on your retirement and enjoy the car.
We'll See!
Sweet ride, only needs this little mod
Was just on the forum looking some stuff up for my jeep and wanted to give yall an update on @DuncLJ s Jeep that my buddy bought, within 15 minutes of me telling him about it being for sale....
Most recently it has been pulled apart to get a GenRight cage put in it.
In July we had it up in Breckenridge doing holy cross
In March of 2026 it will be in Moab and in the Summer 2026 it will be back in California doing the Rubicon!
I'm still pissed I didn't buy this Jeep and I already had an LJ!
