Here is a video of what I am experiencing. Is this normal for a TJ or excessive?
2" body lift, 33x12.5R15 tires at 28PSI, front springs are 12" high, rear springs are 8" high.
What I have done:
When I push down on the front bumper and let go it keeps bouncing for a while. Usually I would say "bad shocks" because there is more than one bounce, but how could that be in my case?
Thanks, Andy
What I have done:
- Installed new Rancho RS55128 on the front and RS55240 on the rear two months ago. Noticed only a minor improvement
- New front anti-sway bar bushings and end links, torqued to specs in FSM
- New rear anti-sway bar bushings and end links, torqued to specs in FSM
- With the vehicle stationary I have tried physically moving suspension parts and nothing is loose
- Front and rear lower control arm bushings are rotten. I haven't looked at the uppers but I would presume they are the same.
Thanks, Andy
