ohh ohh ohhh, I have the 5 speed and 33s. 4.56 or 4.88 if I live in a moderately mountainous area?
2.73's if the salt flat races are your thing
I never measured hub height, I never did any math. What I did do instead was play what if with the calculator. I took several known vehicles we verified the speedo, gearing, etc. and plugged the dash numbers into the calculator and then kept changing the tire size until the calculator matched the vehicle. Works out to roughly the hub height doubled for a rolling radius.BTW, Blaine does not agree that the hub height x2 gives erroneous information and I have never known any method Blaine uses to be erroneous.
So, if you record your RPM in the same gear at the same speed (measured by GPS), at 15 and 30 psi (altering hub height) the RPM will be different?
Why does that matter?
Even more eye opening is the next time you rotate your tires, roll one up beside on that is still on the ground supporting the rig. I just did that and while it wasn't something I was doing for a comparison, it did catch me a bit off guard when the loose tire was almost 2" taller than the one on the ground. I was going to get a pic but figured digging out a level and getting it set up to show the folks that want to argue that I did it wrong wasn't worth it.
So for my build... I'm planning on stretching my TJ to an LJ with 115" WB with a WMS to WMS of 70", or about 84" wheel bubble to wheel bubble on Mickey Thompson 40" DOT MT's on 17" bead locks with 4-3/4" back space so I can keep a really good scrub radius, 5.38 gears in 1 tons single triangulated front, double triangulated rear... with outside coil overs so I shouldn't need sway bars, probably starting at 100 over 150 springs... sticking with the 4.0 5 speed manual initially but eventually an LS3 with a 4L80E with negative manual valve body... so long story short... I guess my question is... do I go ahead and get lights... or lockers...?
Look again... even BFG, its manufacturer, says its actual diameter is 32.7" at the bottom of the screen shot.
Hey Jerry, we can agree that the free length of a coil spring, and it’s length with the weight of the Jeep on it are very different, correct?
I think the manufacturer knows how long the spring is; I blindly use their spec without thinking about the practical application of that information!
It doesn't. Just a fun distraction to turn over. Do you know if radial tire treads lengthen in circumference enough to matter within usable pressures (say10-35psi)?
Interesting plan. Have you thought through how you will clear a triangulated front? Also, what about outboarded coilovers negates the need for sway bars?
2,500 RPM per the Grimmjeeper calculator assuming the tires are actually 33” diameter. Higher RPM at 70 mph is ideal but this is the best you can do with those axles.
Perfect, right at 2554 at 70 mph in OD. And don't forget, the bigger the tire diameter the more rpms from the engine it needs. The same rpms that work perfect, for example, with 30" tires would be nowhere adequate/high enough for 33's or 35's.
That isn't really how it works but good luck to you any way.I have heard that it can be done though and still have an amazingly stable platform... we shall see![]()
That depends on the tire size but the bigger the tire the more rpms it needs.Sorry if I missed it but what RPM range is ideal for 65/70mph on the 4.0 with the 42RLE?
