Unloaded, my LJ sits as close to perfectly level front to rear as I could have ever achieved, though it wasn't through any specific intent, or effort on my part. The top of the tub behind the doors is about 1/16" lower than at the tail, so maybe total 1/8" of rake across the full length.
But it LOOKS like it's squatting. I would have sworn it was half to a full inch lower in the back but I can't argue with the tape.
I have some 3/4" spacers I can throw in, or I could buy the rear set of Rockjock springs to match the front. Curious what you guys shoot for that looks right to your calibrated eyeball, or what you typically end up with using springs from the same manufacturer at both ends instead of the mix and match thing I have going on.
I'm not messing with spring measurements because the curve of the rear makes it too weird to get directly comparable measurements.
