Vacuumed all the leaves out and finally put the top and doors back on. Looks like all the the nice warm days and nights are past, as I usually leave them off from May till October. I'll still drop the top and doors for the occasional pretty day though.
On the plus side, the stereo upgrade I did back in July is really shining now that all the sound is trapped inside and not getting muffled by the wind.
I'm about to see if my stereo upgrade was worth it soon. I have maybe 3 or 4 days of good weather left before I put the top and doors back on myself.
I finally got around to replacing the hemorrhaging wheel cylinder on the passenger side! Not a hard job at all with the exception of getting the spring back on (which is just the reverse order of removal). An added bonus of removing brake fluid-soaked hardware is it's already lubricated and pretty easy 😂
Not sure if the PO had just done rear brakes before selling, or if this wheel just hasn't had functioning brakes for 7 months but the shoes had plenty of meat on them! 🙌
Did you spray the bejeezus out of that drum with brake cleaner to remove all the leaked out brake fluid and debris that it has caught?
Actually was yesterday, but I put the top back on. It was 70 and above all last week, until yesterday morning. Yesterdays high was in the upper 40's low 50's.....And the forecast is not any better.....Friday afternoon
Sunday morning
Should probably wash it so the rest of the Jeep matches the doors in cleanliness. Or Not....
For the past week or so.... the instrument cluster display lights/headlights would occasionally go dark awhile after the MFS parking/headlights were selected. Wiggling the parking/headlight switch would reenergize the instrument cluster lights and headlights.
I have a spare OEM MFS in the parts cabinet, but instead of just replacing the MFS; I decided to clean the switch contacts using DeoxIT D5 contact cleaner to deoxidize the headlight switch contacts.
Removed the (2) screws for the steering column plastic clam shells, the (2) T20 screws and disconnected the harness connectors to remove the MFS. Sprayed the DeoxIT into the switch and cycled the switch numerous times. Tested the parking/headlight switch and the problem has been fixed.
Taking my time the entire procedure was approximately 30 minutes.
I am keeping the spare OEM MFS for when the parking/headlight switch cannot be repaired with contact cleaner.
My transmission was leaking and I was thinking that it was the transmission oil pan gasket. No idea for sure, but I just replaced it with a Lube Locker gasket.
At this point, here is the list of things that I have completed on this Jeep since I got it in July.
  • Front brake pads (BMB), rotors, and calipers
  • Rear brake wheel cylinders
  • Rear brake shoes
  • Rear brake internals
  • Adjust rear brakes
  • Adjust parking brake
  • Flush the entire brake system
  • Water pump
  • Thermostat
  • Thermostat housing
  • Cooling system hoses
  • Radiator
  • Cooling fluid overflow bottle
  • Flush the cooling system many times since it was a nightmare and was basically filled with sand and rust
  • Oil sending unit
  • Flush the power steering fluid
  • Transfer case drain & fill
  • Front diff drain & fill
  • Rear diff drain & fill
  • Washer fluid hoses
  • Radio
  • Radio (again)
  • Front speakers & speaker popds
  • Rear speakers
  • Steering stabilizer
  • Replace rear shocks
  • Rear sway bar end links
  • Front sway bar end links
  • Install deep transmission oil pan
  • LubeLocker transmission gasket
  • 1" wheel spacers
  • Replace headlights
  • Replace headlight bezels
That's a lot in 3 months. I have never even changed my oil in my main car before I got this Jeep. I bought this as a project, and I have completed a lot during this project. I have learned a lot on the Jeep and cars in general. It has been a blast. I know I've been spamming this thread with progress and questions, but this community has really helped me out. Helped me figure things out, helped me do things the right way, and helped me with confidence to tackle more and more stuff.
At this point, it is "done" for now. There are still many things to do to it, but I'm going to take a break. I'll pick up probably the week of Thanksgiving and start doing more stuff.
But it feels really good to be done...for now.
Reactions: Kiwi TJ
Yesterday I installed 4 KM3's (I'll swap the spare tomorrow morning) Huge difference from the TrailGrapplers. I can now travel at illegal speeds on the freeway without the Jeep feeling like it's going to shake apart
Today I swapped the rear trackbar axle side bolt, it's amazing how much drama that one little bolt can cause when it won't snug down (threads stripped) to spec
You should try them out on pine point 10/21.🙂
Reactions: John Cooper
Well, I have a pot of Red Beans and sausage bubbling on the stove, and the rice cooker is doing it's thing. In the meantime, I decided to try on a half door, since they are finished except for some door pin inserts that I have on order. Figured I might as well see how they look.
They look great! The red is just a shade darker than the factory paint (or maybe I didn't put on enough coats), but I really like it, and it's close enough that it won't bother me!
I loved it so much that I swapped on the Driver's side too. I figure I'll run 'em for the next 3-4 weeks, when the weather gets too cold to go without half of your doors!😆
Looking good! They look a little flat right now compared to the body. Once the paint outgasses and you can put a coat of polish on them, should help bring them closer to the OEM paint.
Reactions: 97TJNM and Kiwi TJ
