GMRS antenna
Zorba
"The Veiled Male"
Lifetime Supporting Member
Merritt Island, Fl
The little magnet mount unity gain GMRS antenna that came with my Midland has turned into a mass of rust. It worked well enough for what it was, but it now needs replacing. I know the 6 dB whip is better than the 3 dB "ghost", but I'm leaning towards the latter anyway as I figure it would be fine for trail use. But as the 3 dB ghost is actually slightly smaller than my old unity gain - I'm a bit dubious. Short antennas tend to be more of a dummy load than an antenna - any experience here?
And where/how do you have it mounted?
I installed the 3dB ghost antenna on a windshield corner light bracket. It receives well and I hear a lot of conversations on the local repeater channels. I have made a couple of radio checks and have received responses, but haven't had a chance to try it on a trail run yet.
For the less than 5 miles yall will be strung out on the trail, a "Ghost" antenna even mounted low on the jeep like seen above should be more than adequate. hell you could see decent success with a handheld, and the ghost is significantly better than that.
Now if you are trying to get into town from the hilltop 20 miles away, that's when a proper antenna with a good mounting location starts to really shine.
Exactly. I'm not trying to tune in Tokyo, just keep in touch with someone a mile or less ahead of me on the trail.
Reactions: freedom_in_4low
Although a compromised antenna, it should do fine for trail comms on short distances. I have the 6db gain Midland above my tail light on a bracket.
Mine is a Midland 3dB gain Ghost Antenna. Mounted on my cowl. Shocking how far I can reach. Several miles on relatively flat’ish terrain. Sounds like they are standing right outside my door…
Reactions: Zorba and L J
Yea - I was looking at that thing. Just don't want to induce rust with the grounding screws.
They are just set screws. No need to take them to metal. I have a thin rubber/polymer piece that is under the cowl that I tightened them into. No paint was harmed. Works like a champ…
I use the same mounted similar. Works great, really surprised how well its worked in mountains and forest
Reactions: deadbeat son
