Would anyone have one of these OEM rear tow hooks, or know where to find? I didn't have any luck at my local junk yard or searching eBay. Thanks
That's only meant for use as an attach point when being carried by something like a car carrier. It's not rated for offroad recovery uses.
Try sending a request to Daveys jeep in Ohio or parts breakers out in Colorado.
Says who?
I think those mainly came on Rubis, but not positive.
And yes, they are made for recovery.
OP, Keep an eye on Offerup. I snagged one from TX a couple of weeks ago For a total of $20 shipped!
Thanks. Never heard of offerup.
I don't use it (yet), but I've heard it's the new craigslist.
I just heard back from Jim Repp who recently retired from Jeep as their senior most engineer... aka the father of the Rubicon Wrangler...
My question to him...
Hey good morning Jim, quick question for you about this hook that came on some TJs. Was it designed for offroad recovery use or was it primarily meant for use when the Jeep is being transported and just needs to be secured? (I attached a copy of the photo in post #1 above to my message to him)
Jim's response...
"Its a tow hook. Validated to 1 1/2 GVW. At 30 degree angles as well." (15 degrees per side)
The TJ's GVW is 5,000 lbs. so that means it's rated to 7.500 lbs. Not quite the typical 9.5-10.5K lb. rating of the recovery hooks we typically install onto our TJs.
What terms did you use to search? Rear Tow Hook? Rear Recovery Hook?
