I might have run out of patience trying to diagnose a crank no start problem with my 2002 Wranger Sport (4L I6).
I watched Ivan diagnose a seemingly undiagnosable problem here. He included a link in his summary to a diagnostic tool that Amazon says is not available. I saw others at Amazon (e.g., this) but before I spend a lot of money on a tool, I was hoping someone here might be able to recommend a substitute for the one Ivan cited.
Regarding my specific problem, In summary, I had a P0505 that I tried to reconcile by cleaning the Idle Air Control intake as Jerry mentioned. I drove it for about a half mile and the engine died. It cranks but won't start.
I bypassed the fuel pump relay and it delivers about 43 psi. When I shut it down, the rail holds pressure. So, I don't think it's a fuel pump problem.
I pulled the ignition rail and tested for spark to the block. No spark.
When I separated the crankshaft position sensor connector and tested for continuity between the B and C poles, I got infinite resistance. I got some resistance between A and B poles which I think is normal. I think the A pole is for 5V supply and B is the common ground. I know that doesn't prove a whole lot. In fact, I'm not feeling confident about anything after watching Ivan's video other than feeling like I need to buy a good diagnostic tool.
The bottom line is that it seems really wasteful to buy a replacement part without knowing how to scientifically and completely test that suspicious part.
I've looked at the 2002 TJ Service Manual and the list of inputs to the PCM during engine warm-up mode (open loop mode) is daunting: crankshaft position sensor, intake manifold air temp sensor, map sensor, throttle position sensor, camshaft position sensor, and others.
