So I’m looking for a possible tail light mount for my cb antenna and I’m wondering what would be the best option. Anyone have experience mounting there?
I will be installing one of these soon and I was wondering how you get the cable to the bracket? I know there is a hold behind the taillight, but do you drill a hole in the bottom of the taillight to pull it through to the bracket?
X2I ground off the powder coating were the attachment bolt goes through to the tub as well as where the antenna mounts to the bracket.
What about those who put their antenna on the drivers side? Do you drill a hole in the light housing?
I have the drivers side Terraflex bracket and just ran my coax between the tailgate and hatch glass.
Sounds good. Have a photo? I sometimes run the hard top but mostly soft top and wonder if this set up would work with both?I have the drivers side Terraflex bracket and just ran my coax between the tailgate and hatch glass.
I used to run this bracket and routed the coax between the plastic tab of thr soft top that hooks in around the corner and the short but that you undo to pull the tailgate bar from the back window. I put a short section of split loom to avoid any rubbing, been that way for 6 years now.Sounds good. Have a photo? I sometimes run the hard top but mostly soft top and wonder if this set up would work with both?
