Several issues.
I'm a perfectionist.
I bought a 25 year old Jeep. Everything the PO's tried to fix, they did half-ass or not at all. When I start working on one thing, I end up working on two or three things.
You know how things snowball. I pulled the seats to run a tap down a couple of the mounting holes. I didn't feel safe with the seats moving all over the place. Each seat only had two bolts and neither of them were correct. Since the seats were out, may as well pull the console, clean under it and paint it. There was overspray on it and the shift light was out. I pulled 14 coins, 3 pens, a bunch of toothpicks, a baby sock and about a 1/4" of muck off the top of the hump. The console only had one screw holding it in. The seats and console are out, so may as well put down the Kilmat and install the flooring. Meanwhile, figure out what bulb I need in the fog light switch since the radio bezel is off, screw around with the wiring on the HVAC, run the backup cam wiring, wire in a power port under the dash for the USB plug and phone charger. Get rid of the extra wiring behind the dash that isn't connected to anything. I also noticed most of the fuses were corroded and some of them were the wrong amperage. Replaced all of them.
So yeah, installing a radio is easy if that's all you are doing.
My last Jeep that wasn't new was almost 40 years ago. There is a learning curve.
On my 65 and 67 Mustang, I can rip through almost anything in a day, but I have owned vintage Mustangs since I was a kid.
Depending upon the coins, it could be anywhere between 14 cents and $3.50 that you found! Score!
