Question for you electrical gurus out there...
My OEM locker switch light does not go off, even when key is out of ignition. I am talking about the amber light on the switch itself. The rear locker is an ARB, works fine. Front locker is still factory, works fine. Dash locker lights come on and off as they should when lockers are engaged or not. After several days of Jeep sitting, this little light ends up draining my battery. I have now disconnected the front locker wiring harness from this switch hoping that this switch is the culprit.
If not, do any of you have any other ideas?
Thanks in advance...
Have you checked the switch with a multimeter?
See if the power and ground have continuity when its in both on and off positions.
I’m surprised the locker works correctly though.
https://www.fluke.com/en-us/learn/blog/electrical/what-is-continuity
Mike, did you get this figured out?
I have gotten as far as when the switch is disconnected, the battery doesn't drain. I have been slammed with work so haven't had a chance to dig into the switch itself, hopefully in the next weekend or 2...
I have had the Savvy corner armor sitting in my shop for 2 years...I am finally making progress on the install and I am guessing this would be a whole lot easier if I had a straight tub...I am taking my time and hopefully, will finish up tomorrow with this project...
And that's a corner wrap...
I have decided to powder coat to match body color but won't work on that until after the summer Jeep trips. I will be adding back my flares as well. I also ordered up a new dash lock switch as I believe mine is messed up after I ran a continuity test on it...still left to do is raised body mounts but that will have to wait until winter time...
Looks like they need a test run in the virgocon
Spent the last few days on the Rubicon Trail with pals at the Auburn Jeep Club annual run. It was the cleanest run the 8 of us have had, not a wrench was needed. In all of the years I have run this trail, I have never seen as much water on it as I did this past weekend. We had perfect weather and I thoroughly enjoy this outing year in and out.
going down into Wentworth Springs:
Little Sluice:
more Little Sluice:
Wentworth Springs:
On the way out Sunday, I ran into @Alex01 who was running into a rock wall...
Lastly, I had ordered a replacement locker switch, of course, that one was DOA. I took mine apart and found this:
This one works, but the indicator light won't go off at all, which ultimately drains my battery. My temporary solution is disconnecting it until I need it next. I will order another replacement with the hopes of better luck.
Little Sluice:
more Little Sluice:
Wentworth Springs:
A bit right and a second gear bump did the trick lol.
I need a front stretch to the tires hit before the bumper.
Glad you had a good trip. The mosquitoes were killer this year. So much water.
ran into the Rubicon Springs yesterday with friends, our 14th year of doing so. We head in from Tahoe, have lunch, swim and head back out. My CJ7 gets the nod on this trip over the TJ...but, if you look closely, my CJ now has something related to many of the TJ's here in this forum:
we had beautiful weather, and a relatively quiet trail...
good guess, but, amazingly, the RMS hasn't leaked since I replaced it 7 years ago. I replaced the heavy roller fairlead with a Hawse aluminum from Black Magic Brakes...
Sorry, that was tongue in cheek. It’s a great looking CJ and looks like a fun run!
I had the pleasure of finishing up the wiring/install of Black Magic Brake's tail lights and license plate relocator/light today. Directions were perfect. The weight/balance and beauty of these tail lights are amazing!
here you can see the difference between the OEM version and @mrblaine's:
Installed:
lights on:
brake lights on:
Hazards on:
Well worth the minimal effort to install these tail lights, and, as expected, fit/finish and sheer beauty of another @mrblaine creation is 2nd to none. I can't think of any vendor out there that offers the service, quality, craftsmanship and fair price that Black Magic Brakes provides.
I recently just clicked over 100,000 miles on my Rubi so a few maintenance items were clicked off. Cleaned out dusty air filter, changed oil to high mileage 10x40 in hopes of eliminating a small RMS leak, changed out the spark plugs to the Iridium XP985's, replaced worn u-joint in the front driveline, replaced worn unit bearings, and replaced OEM front locker with an ARB. My pals at Predator Offroad and Parts Mike installed the ARB/unit bearings/u-joint. The front OEM locker is in good shape, I just wanted to match the front with the rear ARB I already had. For those interested, here is a photo of the old spark plugs (age unknown):
