So you’ve got the grill and fenders out of the way. When does the V8 get swapped in?![]()
Shhh stop tempting me!
Just remember,if you run a mopar v8 we are revoking your man card
You are now on my blocked list….
Nice!! I like the “just enough” notch rather than a huge tunnel chopped out of the rail. I’m about to put an outside the frame forward swing box on mine and I’m sure I’ll have to do some frame rail notching along those lines.
Yeah definitely. I guess I don't have a good before photo anywhere but before I raised the frame up I had half of it cut away to clear the pitman arm and nut and really wasn't sure how I'd make it strong enough like that.
The reason it had to be so high was because of how much I raised my tie rod. If you keep yours a little lower and it doesn't run into your track bar joint, you might be able to keep your pitman arm low enough to clear anyways.
Looking forward to a build thread, that sounds interesting!
I'm considering milling in some wrench flats in my Savvy control arms. The jam nuts can be a real pain to loosen without being able to grip onto anything. Is there a trick to keeping the bar still without wrench flats or a pipe wrench?
I'll try to get some real work done tomorrow...![]()
Makes sense, saves me a job. I’ll try to remember to loosen the jam nuts before I take the arms off the vehicle next time.
Alternately, I keep the calipers on the correct side, get a right angle -3AN to -3AN line, and add in an AN banjo adapter. There is more cost and failure points this way due to the extra parts. Each idea should ultimately be fine though.
