The weight of his balls in the driver seat helped keep the front end down when approaching the waterfall.
IDK, they should be above the axle centers so not helpful?
Jeep too short againView attachment 524731
IDK, they should be above the axle centers so not helpful?![]()
That step looks near vertical. If its as steep as it looks, how did you get your fronts up without going over backwards?
See the winch line in that pic?
Same fall different view. No cable hooked up here yet. I’ll be curious if I can start making this stuff with an 8” stretch View attachment 524793
Too bad that pic is a little blurry (video capture?). I love that shot.
I've tried to explain for years how the trails in JV are about the same level of difficulty for the rig on 40's as it is for the rig on 35's. The smaller tires tend to be narrower width so they sneak right through places where the 40" tire rig has to put one tire on top of a 4 foot tall boulder and go over the top of it and try to get past without it putting you on your lid. Like you said, it is all relative and if there was a perfect wheelbase and tire size that worked everywhere, we'd all do it. Wheelbase and lots of it is fun until it isn't.I’m at 115”, and I run into stuff for which I’m not long enough all the time. I also run into stuff for which I’m to long. It’s all relative. Bigger rigs just come up short on bigger obstacles - there are cool challenges at every rig level.
In chasing down a few problems right now…
The first is pretty clear, I’m hearing my tcase bump into my tub sometimes when the Jeep is flexed out or going fast over choppy stuff. Frint driveshaft is also hitting one of the bolts that holds the savvy shift plate to the tub. Those noises are new… My skid is pretty dented so it’s probably just pushing shit higher than it used to be. The other thing is the tcase feels a little floppy just grabbing ahold of it so when I drop the skid to flatten it I’ll check the trans mount.
My 2nd problem is that when I’m at a dead stop and hit the gas hard, I get a big old stutter. Like the feeling of driving over really rough washboard road. Only from a dead stop in first. If I already have some momentum going I can hit gas hard and no worries. I pulled the driveshaft last night and inspected it and it seems fine. Probably not pinion angle because it’s fine at fast speeds although I’m sure the angle isn’t perfect right now with the bent skid. Maybe transmission mount is smoked? Maybe same issues that are causing tcase to hit the tub? I’ll report back when I drop the skid.
Same feeling happened with me on my CJ7, turned out to be the forward mounting bolts had backed out and was causing the transmission to move around...
the forward mounting bolts on the transmission mount?
the bolts the screw into bell housing had backed off, most were missing
Bellhousing bolts were there but thanks for the tip!the bolts the screw into bell housing had backed off, most were missing
