A couple of stills:
Inside of the battery box:
Fountain before filling showing the pump:
Filled up. You can see the battery box under the LH bench:
How deep is the hole you’re standing in.
I laid the camera on its back at ground level in the center. 180 degree view with this fisheye lens.
That's pretty dang cool!!!!
You can get it at Tractor Supply. It will kill brush and other broadleaf weeds that glyphosate (roundup) won’t. I use a mixture of both to spray weeds because 2-4-D will not kill grasses.
