[emoji106]Success!
I love it when a plan works.
Today the check engine light went off. It is the 6th cylinder mis-firing.
Question: should I fix it asap or it can wait until the weather gets better?
hmn, I thought if you say went off that means it is ON.You say it "went off", does that mean you no longer have a light? If you have a constant misfire that you can feel, I would be concerned because you're dumping fuel in to a cylinder that's not able to burn it. However, many misfires are just cold misfires and the cylinders are actually firing correctly after a few seconds. I would rush to fix the former but not the latter.
You a long way from home mate !...did you take a couple wrong turns ? lolhmn, I thought if you say went off that means it is ON.
Yeah, I hope it's just the weather, I am in Clinton Iowa when the engine light went off (on). It is darn cold up here![]()
Well, after taking apart my rear sway bar and links, I lubed up all the fancy new bushings I ordered only to find that I left my big c-clamp back home.
Looks like i’ll Be driving to work very carefully tomorrow AM, then borrowing the u-joint press from Autozone on the way home.
Today I greased the CAs and steering system. I broke the seat release lever (will use bike cable to fix). One day I'll break down and buy new seats.
Going to have to look into that one. Sounds way more stout.I used a diy motorcycle clutch cable kit for mine and it's a beast! No more risk of the cables snapping anymore.
Sent from my SM-N950U using Tapatalk
lol. It is job related. I now work in Iowa.You a long way from home mate !...did you take a couple wrong turns ? lol
The bushings in the links will never go in by hand. Far too tight.What did you need a clamp for? I replaced my rear sway bar bushings with just my hands.
