@jwilkinson01 can you recommend a Np242 rebuild kit (or anyone else). One with GOOD diagrams, good identification of what seal is what etc... I got a kit all the parts just chunked into bags and into a shipping box. After complete confusion..... discovered after some phone calls and emails.... the kit ended up being a multi - vehicle one.... so some seals in kit are are used on some vehicle's by spec...... where other seals are used by other vehicle's by spec.. so you have "extra parts" that will end up NOT used in your version (such as Jeep).... well NONE of that is specified by the kit seller...they offer zero paper work, etc to show you what goes where and with what vehicle versions of 242,.... .. the seals have NO numbers on them so you can only Mic. them out to see what matches and looks similar... but that still leaves huge doubts cause they are still just little different in what you removed .... then some superseded parts are in the kit too....... so you end up with seals from the 242 you pulled a part..... with seemingly NOTHING in the kit your confident should actually be used , much less where to use them!!! AKA what should have been a simple swap out old parts for new..... turned into an absolute NIGHTMARE of a month of daily work on it (and other things).
Needed my TJ driving 2 months ago..... didnt have a choice but put 231 back in. Anyway..... maybe this winter will attempt finishing rebuilding the 242 ... thus seeking advice on a second rebuild kit so at a good point; can start all over.
Became so !@#$%%^&* frustrated that every single seal I removed..... didnt have a match in the kit .... sadly gave up after nearly a month of trying to search everything and get things to match in a way was confident that 1000 miles down the road the T-case wont blow up due to putting wrong seal in.. or backward. Closest affordable T-case rebuilder I can find is an hour away... since got nothing to drive unless I rent a car that threw a wrench in that idea. Stupid piece of shait 242 kit cost me HUGE in time and money
Modifying generic H. Freight style jack to transmission jack with an adapter and installed the 231 ... Sadly they dont make that adapter for H.Freight type jacks so you got to modify one of the adapters on the market to get it to work. Not a complaint..... knew would have to do build or buy a used transmission jack no matter what. Trivia 242 is heavier than 231 as well. Granted; 20yrs ago would have just bench pressed it and used my third arm to start the nuts.... but yee ol' shoulders cant do what what use too or. Anyway..... finally got 231 back in.
Working to start engine now (it is new to me also)... slow progress forward
Once again- Any good rebuild 242 Kit suggestions out there? one's with with real parts breakdowns, instructions, etc..
I used Novak's kit, and while it was a good kit with quality parts, it was NOT crystal clear, The directions definitely left a lot out. It also came with additional parts, mostly seals. I think different years had different seals and it is easier for them just to throw them all in and let the customer figure it out. I definitely had to make some judgement calls because what I had in the kit didn't look exactly like what I pulled out. Also, my TC was disassembled when I bought it top ship it easier, so I lost out on some of the knowledge you get with taking it apart.
I have a transmission jack from HF and I was able to pull the 231 and get the 242 bolted up in a couple of hours.
