Genright Aluminum Armor Finish
Drastic
Bear Creek, PA
Anyone here running Genright or any other brand aluminum armor? I have Genright door skins, stretch corners and tailgate. Everything but the corners looks great. The corners look almost textured.
Just wondering how you prepped/sanded/cleaned your aluminum.
Reactions: Apparition
Someone sanded your corners with a DA sander probably trying to cover up some scratches , I use a harbor freight surface conditioner tool after seeing stainless steel fabricators use it remove scratches from stainless and blend in the brushed stainless perfectly
https://www.harborfreight.com/9-amp-surface-conditioning-tool-58079.html
They go on sale frequently I think it was 125$ a couple of weeks ago
I finally got started installing my corner armor today , they had been sitting in my garage for 4 years
Easily removed some minor scratches and oxidation you can see in the first picture the before and after
View attachment 565324View attachment 565324
pics
I’ll eventually paint them body color sometime next year,
Easily removed some minor scratches and oxidation you can see in the first picture the before and after View attachment 565323View attachment 565324View attachment 565324View attachment 565327pics
View attachment 565431View attachment 565432
I bought everything brand new from genright, the corners are the only thing that came with a textured finish for some reason.
you can get rid of the texture with the tool I linked above if your looking a brushed finish , just start out with the more aggressive brush then go over it with the finer brush , then the finishing brush which is about the same as a red scotch brite pad ,
I spent around 10 minutes for each side
Was able to remove a bunch of scratches without much effort
It pretty common for metal guys to sand raw metal with a da sander to git rid of imperfections and get a consistent finish
I’ve had a set of poison Spyder aluminum fenders , and my savvy aluminum front bumper for my JKU both had a sanded / textured finish just like your corner armor, I ended up painting both so it was not an issue
I have corners, bumper, doors from GR and nothing has a texture, I left everythig like it was out of the box. I did clean up the edges w/ steel wool
That is a DA finish. Sometimes the folks doing the counter sink work don't pick the best side and it gets turned out so the scratches show. Rather than scrap the piece or send it to some poor unsuspecting smuck like me to fix, they get after it with a DA sander to clean it up and make the finish uniform. I had to fix these with the finish sander mentioned above and was able to get most of it out. If these were to be left raw instead of powder coating, they would have had to go back due to being too deep.
View attachment 565825View attachment 565826View attachment 565828View attachment 565829
Good golly, I know you had a good match for flame red, but I had to do a double take to realize the armor was actually installed in that last picture. My first thought was "why did he install the gas cap back on the tub without the armor?"
It is a good match when you consider the tub and rail above the armor are the stock color. Incidentally, the next one I had painted, they completely freaked out because I had them color match the paint to the powder coated grill. They said the color was too far off for it to even be close to the stock color and they used that as an excuse to try and get out of the color matching correctly. If you were wondering how that went for them, they did respray it all with the correctly matched color finally. Same color as above.
Do you happen to know what the brand and name of that powder coat was? That looks amazing!
I may missed it before, could you share about that bolted fishplate looking thing?
Reactions: Tob and shortydog33
I have nemesis aluminum front highline fenders, rockers, and extended corners, UDF alum engine and tummy tuck, Savvy gas tank, genright front bumper, and savvy rear bumper. I didnt prep them at all. Honeslty, I don't do anything to it unless it's got so thick a coat of mud that the rain won't wash it off.
