New to Jeeps and TJs
Txguy_newto_tjs
Texas
I bought a used 2006 jeep wrangler TJ 2d with 4 inch lift kit, rancho 5000 shocks, 33 in cooper discoverer stt pro tires, soft top from bestop, winch on the front (no idea what kind). The engine sounded rough but put stp treatment in tank and engine sounds better. So, new to community and would like to know what the veteran jeep owners would check as I need this jeep for a commuter vehicle back and forth to work 3 days a week about 50 miles one way on highways. Any info would be helpful, thanks.
Reactions: inkedrose
There are thousands of posts about what to do after purchase.
Do a search and you'll find multiple lists and they all start with changing every fluid in the vehicle including the wiper and blinker fluids.
Thank you I’ll look into that
  • Face Palm
Reactions: TJ Jim
Pictures and more info on the Jeep will help .
Engine , transmission , gear ratio ?
What is your intended use other than back and forth to work ?
A good all terrain tire would be better or more comfortable for the highway driving .
50 miles each way...soft top to boot. Id start with a box of ear plugs.
Check frame for rust
Change plugs (iridium or platinum tipped)
Change all fluids
Now you have a baseline
Get a gas card! You’re going to need it!. 🙂
Reactions: MikekiM
You should have bought the TJ 4d instead.
Don’t have a need for one
Engine is a 4.0 6 cylinder, automatic transmission, 4wd, I am not sure of the gear ratio but think the rear has a Dana 44 on it. And do you’ll have recommendations for all terrain or all season tires?
What don't you like about it?
Just the way I can feel everything when riding on the road and have yet to take it off road. Have to slow way down for dips. A little confession, I came from a Mustang to a jeep tj.
Check the tire pressure. 33s should be around 25psi. After that, shocks are what determine the ride quality.
Reactions: MikekiM
Correct on the Dana 44 out back.
You're in TX so rust is less of a problem but who knows where the Jeep spent most of its life. Drill some drain holes in the frame, treat the inside with some Fluid Film and if you care, clean the outside of the frame and give it coat of POR15.
Might want to swap the battery cables.. those look like the originals. JeepCables.com
Tires.. You're ready for a new set. Though there is still some life left in them, might still make sense to change since you'll be commuting. I have Falken WildPeaks. I daily drive mine. Like them well enough for four season use, but I see snow up this direction.
You didn't say how many miles it has. Super low is arguably worse than higher miles. Stuff dries out, brake lines and calipers clog and seize..
Change all the fluids. Go hose by hose and change any that are looking brittle.
The ride.. no reason it can't ride like a dream. Start with tire pressure... notoriously set too high. Maybe the cause for the excessive wear in the middle of your tires. Generally agreed upon 26 - 28 psi will result in a better ride. I have 33x12.5 on similar (if not the same) wheels. Tire pressure is 26psi unless loaded for camping. Ride quality is great. Makes me giggle when I drive it.
First image shows just a peak of your headlights. Do yourself (and others) a favor and get rid of the OE sealed beams. Tons of options, but the Toyota/Koita H4 kit is hard to argue against. H4 replaceable bulbs, HD harness to run higher wattage if you want and typically less than $40 for kit of late. There are a bunch of threads on this. Dig around.
Worth it to check the gearing. I don't know what's best for an auto, I have a 5 speed, but 33's will likely cause issues with the trans hunting for the right gear. Not urgent and not cheap, but once you get the gearing dialed in, you'll wish had done it sooner. This and tire pressure make a huge difference in the driving experience.
So my tires are at 31 psi so I’ll hook the air down system to em and drop em to 28 psi and see how that is and adjust if needed. I’ll look into the headlights you suggested, and tires. It has 188,000 miles on it. It has only had 2 owners before me in Texas, that doesn’t mean they only used it Texas. The shocks are ranchos 5000s so my upgrade to the 9000xl. You’ll are all awesome thanks.
