You're sliding it up and down the helical gear. I don't remember how much mine has, but it has some.
If you want to double check it after installing, you can remove the pin, rotate the crank around twice and everything should line up again. You only rotate the crank clockwise as that is the way it will run in operation and accounts for all the slack.
What brand was yours and was it your old one or a new one that would slide up and down some. I just assumed it wouldn't have as much play. Seems like if it can move up and down on the gear it could effect the timing? I might just remove the top of the new one after it is installed and see how much it moves.
Once it comes I am wondering if I should keep the Crown sensor or just use my new NAPA sensor. Might could return the NAPA. Read a few comments saying the newer Crown sensor were OK.
