Got the rig back from the Axle Shop (although it needs to go back to finish a step), and drilled out the brackets, installed the PSC rear bumper reinforcement brackets, and got the Smittybilt Tire Carrier on the rig. Wired up the license plate / 3rd Brake Light, and am waiting for Sharon to return from 4WP with a spare tire License bracket.
Tried fixing my leaking brake junction, and ended up making the leak worse. Back to the drawing board on this one. The bolt goes through the junction block (onto a surface; in this case my truss), and then the two left and right lines screw into the junction. The lines are dry and not leaking, but it is weeping out of the hole that the bolt goes through. I put copper washers on each end, and made matters worse. [emoji848]
Well, I made enough progress to bring the rig home tonight for the first time for a little “visitation”. Installed the bumper, license bracket, wired license plate/third brake light, fixed the leaking brake issue, installed the sPOD, and changed the oil for the first time.
It did come home for a brief visit, so I can wash it for the first time, and get all of the grinding dust and metal off of the fresh paint and wax her up.
Back to the shop tomorrow to begin to dial it in... plus, I need to figure out how to get the spare mounted due to a bolt pattern issue. (Frustrated on this...)
Well, it begins... Shari just took it on it’s maiden voyage from the shop to our house.
Still much work to do to dial it in, but it is much closer and able to move now.
Some subtle custom made decals in matte black for the Jeep logo, and the rig name in anthracite to match the roll-cage. #SundayNightDetails
#OneStepCloser #JeepTJ #StretchedTJ #Jeep #TimeToGoTopless #CoyoteUgly
RC
Sent from my iPhone using Tapatalk Pro
