I was asking if he had an oem driveshaft before the swap or if he absolutely had to buy a new driveshaft. I was asking because not long ago I finally installed the sye I had lying around and bought a new Adams driveshaft. I’d rather not spend another $300 bucks if the one I have will work when I swap the axle. Are jl/jt brakes bigger?A new rear shaft is like $300, do it if you need to. Do you have a rubi.? I needed a new shaft due to the SYE when I did the jk swap. On the front I was able to reuse the stock driveshaft but I did push the axle slightly forward.
If you have to buy brakes buy JL JT brakes they bolt right on with their respective rotors.
