Console Cooler Conversion
JMT
The Silver Fox 🦊
Anyone done this? Just drill a hole in the bottom of center console, add a plug, use for cooler when needed and storage otherwise.
Are you planning on putting a cooler inside the center console area? I ask because obviously if it's a cooler, it needs some insulation.
Im thinking adding a cooler inside is what @JMT meant. Otherwise it might be pointless as I feel like the heat from both outside air temp and under body temps would cause the cooling effect to dwindle pretty fast.
Is the console lid air/water tight?
The console lid is not air / water tight, no way. Wouldn't matter anyways, since the console itself wouldn't work as a cooler.
If you were to somehow fit a cooler inside the console, that would have to be one small, odd shaped cooler.
@JMT clearly left out a LOT of details with this post.
https://www.google.com/amp/s/gizmodo.com/393176/ford-adds-a-fridge-to-the-flex/amp
The Ford Flex came with a fridge option for less than $800.
If you are willing to lose the factory console, then I could see building a cooler to fit in between the seats. In my build thread you can see how I crammed a large ammo can into that space. Add some rigid foam insulation panels and there should still be enough room for some sandwiches and drinks.
Reactions: KCsTJ and JMT
I dont mean to sound like an ass, but are you serious?
You sound like an ass bro! It has been done with a constant drain...
Not a cooler inside the console, just use the console as a cooler. Literally, drill a hole in the bottom, put a drain plug and fill with drinks and ice. I only need it for 5-6 hours.
Many coolers are not airtight
I think @JMT was speculating, you know throwing out creative Jeep ideas for us to ponder :)
I like the convenience of the idea personally
Yes, this is what I was doing. Why not, right? Even if you have to add some insulation, you could get 5-6 hours, use sealed ice blocks rather than loose ice.
Dry ice is really nice to use if you can find it. No need to worry about drainage or stuff getting soggy as the day goes on.
I've had a Twix sitting by itself in the center console on a road trip, went to grab it at some point and it was completely liquified. Point is, that area gets really hot and I don't think ice would last very long at all.
The area below the console would probably need some heat shield stuff like whats under the front carpet, and yeah those ice blocks I think would be better than ice for this. I say go for it, and let us know how it worked out and if there is anything you would do differently.
I have always been a fan of the idea of a console cooler or a glove box cooler. Though maybe that was when I lived in the endless summer...and was constantly dying of dehydration.
Reactions: Jeffreybomb
Could you? Yeah.Trying to be open minded here..it would save you space like if you were wheeling with passengers and gear.
That’s exactly my situation. I always wheel with a passenger in every seat. I’ve moved my Viair 88P under the hood. I’ve got a small toolbox that I usually place in the tiny TJ trunk area. I also have my tree saver back there. I have some room left for a cooler back there, but it’s got to be a very slim cooler or soft back hopper style. The Rubbermaid 20qt slimline (~19”x12”x7.5”) will fit the bill, but it’s a bit cumbersome to get into while wheelin. Something in the cab is ideal, but with every seat taken the only place left is the console. I may end up just getting a cooler for the rear, or even do both. The console is just so conveniently located for the front seat driver and passenger. I like the “dry ice” idea @jjvw suggested. I’ve used it before in coolers and it works very well with a layer of regular ice on top. It is a little pricey, but space is everything in a TJ, and it’s only for wheelin’ days. Any other ideas, especially for some kind of insulation? I know the driveline gets hot, so I’m going to put my hand down in there a few times this week while I’m driving around, see just what kind of heat we’re talking about.
Throw a thermometer in there to get a better understanding on what's needed to pull this off.
Reactions: Jeffreybomb and JMT
Maybe some 1” blue poly foam sealed with acrylic latex silicone. Dry ice on bottom, sealed ice blocks on top. Even if I could get 4 bottles of water in there it would be worth it.
What about insulating the gaps between the inner console and outside molding, that you see..stuff it full of insulating material to slow down the heat, and while the console is out thermo mat the floor board under the console..itll save you space inside the console while your saving space outside..lol
Reactions: srimes
