1997 TJ 2.5l manual, no crank no start. I replaced all the ignition components under the steering wheel, new starter relay, brand new battery. I have bypassed the clutch safety switch with the factory bypass plug. All grounds have been cleaned and tightened..
I assume the starter works, I jumped across the solenoid with a screwdriver and it worked. When I turn the key to start it, I hear a click under the dash behind the speaker. After inspection, I can feel this relay click when I turn the key to start.
What is this relay?? Any suggestions on moving forward in troubleshooting?
