Not sure. My skids are made for me with a 1" drop x 13" wide in the center to match up to engine skids under trans oil pans. From the sides of that 13" section, they go up to the frame and then return to flat at the narrowest part of the frame so the bend winds up just inboard of the frame at the front and a bit more at the rear of skid. The line below is defined by a section of skid we've cut off that we use to see how much more clearancing we have to do so it gives you a rough idea of the hangy downy bits.
That's some impressive work you did. Changing the leaning end bolt to a low-profile flat bolt was a great touch that proves you're always after the most gain you can get.
What size, thickness, tubing are you using for the cross-member?
