Preliminary good news…. It does run. Now to a bunch more work.
Woohoo congrats! First start up is huge
Right or wrong, it did feel pretty good. I’m a little worried though as to how simple it seemed to start , it turned over like 10 times and started like a used Silverado that sat for a month. It shouldn’t have been that easy, though I think I have some issues (fuel or air), my guess is vent on fuel as everything is still plumbed factory with evap stuff. Hopefully I disconnect it and let it vent and it will fix it. It started idled and slowly idled down to nothing. Then it started, revved a bit and died.
Easier than expected is good, no? Hopefully a couple easy tweaks and it'll be idling. I know I was surprised AF when my MR2 started an idled the first time I tried, lol
It is. I was first paranoid as it wasn’t building oil pressure when turning over without spark plugs in. More turning over than I would have guessed ironed that out. Now I’m probably being paranoid it isn’t idling perfectly in its first 20 seconds of running in the Jeep.
It is good to prime them with an oil pressure tank before start up. No old school distributor to remove and spin up the oil pump
Certainly can’t hurt to do that and I probably should have. I did oil everything before I resealed and turned over without spark plugs. Maybe it was a mistake not priming with a pressure tank, guess if/when I have issues I have something to blame![]()
Is that for the brake booster?
Weird what fixing a “small” leak will do.
Built most of phase 1 of the exhaust today. Need to add bungs for o2 and hangers.
Hoping to have the shifter mostly figured out and skid plate one. That will leave a small amount of wiring then reassembly time.
Cool,
Glad it's moving along for you.
