Utah Moab 2025 Parts
Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
In the hills of WA
If you have parts to sell or trade or just give away then post them up here and see what happens.
To start it off I've got a pair of JJ's up for grabs. Couldn't use them on my midarm install.
I've also got a dual battery tray & dual battery kit for a NON-A/C TJ I can bring.
Reactions: rasband
I’ve been waiting for an opportunity like this.
Rear seat belt set: $50
TMR universal crossmember kit never opened: sells for $189 plus tax and shipping, I will take $80
Also, unboxed TMR universal transmission mount, sells for $129 will take $60.
SOLD Rock Jock TJ rear extended sway bar links unboxed. Sells for $33, will take $20 SOLD
Factor 55 hawse fairlead 1.0” p/n 00016, unboxed. Sells for $88, will take $40
Grab Handles, RT Offroad, unboxed, sells for $50, will take $25
SOLD Oracle 13.5” double row LED light bar. P/N 5806. Sells for $120, will take $60. SOLD
Switch panel for 6 OEM and 4 Carling switches. Includes 12v socket and dual usb port. 3D printed, sold by custom3dfab.com for $75, will take $30
Rugged Ridge dash mount, unboxed, $20
Dome light bypass harness, sells for $40, take $15
SOLD Sun Visors, new. Must be for 97-02 as too long for my 06. $20 SOLD
SOLD Painless Performance Cirkit Boss 7 circuit p/n 70107. Sells for $90, take $40 SOLD
Added one more, OEM jack kit. Decent shape, $50
Oracle 13.5” double row LED light bars, 2 of them. P/N 5806. One opened and one unopened. Sell for $120 each, will take $60 each.
I'll take your extended sway bar links and visors!
Reactions: E-Ticket
WOW you've got a collection....
I hadn't even thought of small things like the visors I can't use... That are new...
If I didn't already have the GR crossmember I'd for sure jump on the TMR stuff.
Is the Painless Circuit kit switched or non-switched? Or 3 non & 4 switched? I think that is how they offer them. I don't think I need one but???
My motorhome is already porky...
I don't think I've got the time to find more parts to bring with me.
From the directions 3 are constant power and 4 are ignition switched.
Barnes rear plate bumper with frame tie in brackets and grade 8 hardware. Barnes logo has been welded up. Has some rash marks on bottom, could use a fresh coat of paint. New $136 will sell for $60
Rock Hard rear roll cage bar. New $220 will sell for $100 https://www.rockhard4x4.com/product_p/rh-1001-b.htm
Claytone LED back up light kit for stock tail lights. New, never installed (installed pic is from Claytone's post). Free to good home.
I may be interested in the rear cage bar
This thread is a great idea. I’ve got stuff but haven’t had time to properly clean and photograph but I’ll throw them up any how:
1) built stock axle set:
LP30 with Eaton e-locker, yukon 4.11 gears and 27 spline CrMo shafts. Also Currie mini-skids, BMB elevated sway bar link brackets, Johnny Joints in UCA mounts and cast iron diff cover. Unit bearings are good and early variant (about 0.2” wider than late models). Ball joints are spicer but one is loose. No brakes. Knuckles are ‘98 XJ take offs.
Super Dana 35 with Eaton e-locker, yukon 4.11 gears and 30 spline RGA 1541H shafts. Also ZJ disc brake conversion in good shape, Rock Jock elevated track bar bracket and cast iron diff cover. No brake lines except soft line at calipers.
The axle housings are from a ‘97 TJ with 170K mi. Less than 15K mi on the builds. The axles are straight, smooth and quiet but they have been wheeled in the rocks and have cosmetic scars to show for it. I have a used electrical line for one locker but no switches.
$1200
2) Barnes TJ/LJ/YJ low profile rear bumper with receiver. Barnes logo welded up. R/L Tow points welded on both outside and inside surface. Black powder coated with a few scrapes on bottom.
$100
3) Black Diamond rear TJ 3” lift springs. 15” free length, 11” ride height in my light TJ. Powder coated black.
free (or perhaps 1 can of Johnny Bs IPA)
Reactions: Apparition
This is an a Utah subforum, so it it just for people in going to MOAB for a meetup?
Yes, it was for those who were going to be there and might have parts others were interested in.
Reactions: gbirk
Wow I got stuff. All came out of or off of my 04 LJ
NIB Rock Jock 4” TJ rear TJ springs (3.5”LJ) 9131 RH2P $200
OEM front track bar with bracket and quick disconnect links. FREE
OEM front axle shafts Dana 30 with kinda new unjoints. FREE
Eaton Truetrac Dana 30 27spline and Dana 44 30spline. $250ea or 400 for both
Under Cover Fab no body lift 3/8” belly skid, well used. $200
Metal Cloak 3.5” springs SS 2008 fronts SS 2007 rears $75 a pair or $125 for the set.
SOLD
* TJ Tailgate
* CJ Tailgate
* Orange CJ Grill
* Tinted side windows
I have a bunch of stuff here. If you see anything in my spare parts box that you want, just DM me and I'll get better info/pics.
TJ Bestop Safari Top in like brand new condition. Not even sure if it's ever been installed before. $40
TJ Bestop tinted side windows in like new condition $20
Bilstein 5100 shocks for 4" lift. The front lowers currently are bolt through but can easily be changed back to bar pins. These are in all but new condition with 3 trail runs on them. I switched out to Fox 2.0 RR's. $200
Jeep TJ tailgate in excellent condition with hinges in Patriot Blue $100 just need cleaned up.
4 2" left hand thread inserts. Make offer on what you need
3 each left hand/right hand 1.75" thread inserts. Make offer on what you need.
1.75" DOM One 4', one 3', one 2'. Make offer on what you need.
Various Jeep grilles and tailgates. Tell me what you're after and we can discuss price in DM.
Various parts and pieces, vents, switches, etc. DM me with whatever you're looking for.
