2005 LJ parked it the other night then went out turned key all accessories turned on headlights radio dash gauges but would not crank or start but can rapidly hear and feel the starter relay clicking when under hood and someome trys to Start it . Changed fuses and swapped relay Checked actuator pin no damage. Changed ignition switch and starter but still no crank or start Battery reads 12.8 positive post on starter solinoide has 12.8. Trigger wire getting no power when the key is in start position. Tried jumping from the positve post of starter to the trigger wire in on and start position but only get a single faint click from starter. Any help. Would be appreciated thanks.
