It seems to me that the the relatively thin axle tubes on the DANA 30 (and maybe a 44 also) would indeed benefit by the addition of the welded on trusses. Curries have much heavier tubes, but many late model a lesser to hVe relatively thin.
Although I can run a pretty good bead if everything is set up correctly, I don’t consider myself a real weldor. That, said, I have done enough welding to know that welding on one side of a tube whether square, round or whatever, will cause dimensional distortion. So with THAT said, it seems that welding a truss in place on these standard tube size axles is a common practice, so it would seem that the heat presents no problem. Has anyone ever seen a problem from it or not?
Thanks for sharing your experience.
