Hi all,
I have a 2004 Jeep LJ that I recently installed a 2.5in OME lift with JKS adjustable track bars. I had a shop install the track bars as I broke the rear shock bolts so decided to have them do that as to not deal with that headache. Anyway, my stock track bar had play at the axle side of the mount the bushings ended up being bad and this showed as death wobble when I lifted the Jeep. The shop installed the track bar and I noticed it still had severe death wobble. I got it home and noticed my new JKS adjustable track bar has about a .5in side to side play at the axle side. I took out the bolt and the hole does not appear to be wallowed out and the bolt does not move just the track bar itself. What do you guys think? Faulty product from the factory or something else? The guy at the shop said everything else in the steering was tight and that is what I see as well.
Thanks!
Thanks!
