Started tearing into my new to me Wrangler and am basically looking for some “while you’re in there” tips. Anything I should do while tub is off (seals, cables, etc)
Secondly, I also want to replace the suspension with new non rusty parts. What would you do? I don’t want to lift it really but want to put bigger wheels and tires, 32s if possible. Springs, arms, ends. The whole lot. Maybe it makes sense to do a small lift?
Thirdly, I noticed oil from my transfer case and from the bell housing it appears. RMS?
Besides those things here are other parts I will be replacing:
- Body Mounts
- Brake lines
- Muffler (atleast)
Once I dig into the knuckles and brakes I no doubt will be replacing brake backing shields and all the other rotted parts.
Thanks for any tips and enjoy the photos. Blasted the frame and coated it with SPI epoxy primer. The tub is very clean except for the body mount channels which I hopefully can weld in new ones. Rear diff spring buckets seem pretty bad hopefully can weld new ones on?
- Body Mounts
- Brake lines
- Muffler (atleast)
