OME 2.5" lift in progress!
Roger Dunning
Chichester, West Sussex, UK
Very excited to have this finally happening. I was going to fit myself but the weather ha sturned in the UK and I don't have a garage so it came down to finding someone who knew their stuff!
Still need to work out whether to go for 32"s or 33"s but we'rer getting there.
Reactions: Roger Dunning
I’m fitting the exact same kit… but thanks to Work I’m probably three weeks behind you in getting it put together.
(plus I’m changing the colours)
Looks good though, you’ll have to let us know how it rides.
Well, I cheated and got a mechanic on it 😔 When you say changing the colour, do you mean from the yellow.
Reactions: Kiwi TJ
I'd love to hear more on that
I started with a 2" lift and 31s. In reality the lift ended up netting me 2.5" so it is possible that you end up with a little more. This easily put me in range of 33s by adding just a simple body lift which also opens the possibility of a tummy tuck/SYE down the line. The only thing to keep in mind is you would like need to regear for 33s but better to do that once. I would skip the 32s which were also only available in 12.5 width I believe which I did not want.
Reactions: Kiwi TJ
Yes, this is the question! So much mixed information out there. 3.73 gearing. Pavement princess. Really want to go 33's... We'll see.
I ran 32 inch tires with 3.73 gears for 10 years . I could only use overdrive on flat ground running 60 mph and above . We now run 4.88 gears with 32 inch tires and run approximately 2100 rpm at 60 mph in overdrive .
Reactions: John Cooper
