CB Radio Suggestions?
Chris S
Hanover, VA, United States
This has probably been posted/asked before but I couldnt seem to find it.
What is the best/a good option for a cb radio?
Do i need to tune it or are most ready to go out of the box?
I currently have a 4ft firestik cb antenna
Any other tips?
I use a Uniden Pro520XL CB, an overhead radio mount from http://arizonarockyroad.com., tail light antenna bracket from Teraflex, 3/8-20 stud mount and brass disconnect from breedlovemounts.com, with 2' Firestik II antenna in town and 4' Firestik Firefly on trips.
And yes, your antenna does need to be tuned using a SWR meter.
I use the same one that Alex and Mr. Bills use. Also agree that you need to adjust the antenna length with an SWR meter.
Ever considered a hand held?
A good unit will still cover a big distance, one less thing in the car to attract thieves, and you can use it anywhere (getting out to guide someone, walking, etc etc.)
Reactions: Chris S
Reactions: JeepZilla380
I have a very similar set-up, a Uniden 510xl, teraflex mount, and 4" firestick. Agree with the others to tune it, swr meters are fairly cheap on Amazon or if your lucky someone in a local Jeep group can usually help you out! Make sure you grind some of the powder coating off the external mount to ensure you have a good ground for your antenna.
Sent from my Pixel 2 using Tapatalk
Reactions: Chris S
I use the Cobra 75 WXST with a 3’ Firestik and Teraflex Mount. Works great on the trail.
Reactions: Bert and lowranger
Remember when a CB Radio was a factory option on a Lincoln Continental...
I have a buddy who insists on a handheld unit on trips. Whenever he goes around a bend, over a hill, or a little too far, the reception drops like a rock (much more so than a mounted antenna).
Having a hand held unit can be nice for spotting though.
The antenna is now mounted using the teraflex taillight mount. I ordered a Uniden pro 520XL and a swr meter. Im thinking about mounting the cb to the back of the center console. Has anyone else on here done this? if so do you have pictures?
Reactions: ac_
That might be more the quality of the unit.
My first handheld was a tiny uniden, I think it was about $50 for a pair . Great for walkie talkies, but nothing more
I then invested in a good unit that I’ve never had an issue with.
Mine is not mounted behind the center console, although I may like that idea better I am going to look into it, but instead it is hanging under the dash.
BTW I have the same setup as you, but I bought mine as a set from Clear Channel CB's, and it came with SWR meter. I didn't see what your antenna was, but mine is a 4 foot firefly on a spring, so I can tuck it away in the parking garage.
View attachment 45722 View attachment 45723
Like flame red, and like the roll cage minus the padding.
