Today, instead of taking a nice drive along the OC coast to find some lunch, we turned around and limped home w/ a P0306 (#6 misfire) code.
Light was solid & flashing.
Pulled the plugs, no outliers other than the gap being closer to 0.045 than 0.04. #6 was not soaked, so that suggests no fuel.
I put in new plugs since these have maybe 30-40K on them.
No change... still ran like crap. Confirming my previous fuel concerns.
I don't own (and don't want to own) fuel line tools.
I think this one is headed to a shop for a more accurate assessment & repair.
You can rent a noid light set from O'Reilly's. That will tell you if it is getting signal to fire. You just unplug the injector, plug in the noid light, and start the engine.
I built an attic for the cargo area of my LJ. It holds my half door soft uppers but I made it mainly to carry camping equipment (without the uppers). So far I've put (all folding) ... 1 camp chair, 1 2' x 4' table, 1 side table, 1 stool for roof access and a blanket/tarp roll in it ... and I still have some room left.
Or swap injectors see if the problem moves.
The problem is moving alright...
To a shop! :ROFLMAO::ROFLMAO::ROFLMAO:
Rather than messing around swapping 2 injectors, and then possibly replacing only one, I'd rather pay someone to replace them all (assuming that's the issue). It is still quite possible that it isn't getting a signal to open... which I'm not prepared to troubleshoot in my 'spare time'.
Remember, I'd be into the cost of tools in order to swap the injectors myself, and it's not a job I want to do anyway.
The shop will also have the equipment to verify fuel pressure at the rail as well as compression test- and I'll have them fix the oil leak on the pan bolts above the starter too.
And I'll have him look at the brakes while he has it. I'm growing tired of the maintenance... I only want to do the shit I want to do.
What the hell, I'll probably have him change the oil too!
I've got better shit to do with my time these days.
There is no special tools required to replace the injectors. You don't have to remove the fuel line to the rail. I swapped mine in 30 minutes in the campground on our NYE ride. Just make sure the old o-rings are out and you lube the new ones with a petroleum jelly.
But if you want to pay, then so be it. It isn't hard.
Spot the TJ…
Ok…lunch is the South Island
followed by dinner..( not the dinner I was hoping for because when we got there you saw people trying to eat while seagulls flying overhead) Not my idea of fun so went to Sals instead
Never said it was ‘hard’, I’m just too busy and don’t have all of the appropriate tools or diagnostic equipment readily available.
And w/ 4-5 different things needing attention, I’d rather focus on my other stuff.
Just got back from a walk through be able Tasman National Park… stunning scenery only accessible by boat. View attachment 670100View attachment 670101View attachment 670102View attachment 670103View attachment 670104View attachment 670105
My dad got his tractor stuck today so I had to crawl his LJ and my recently acquired rubicon out of the way. It was 24 F out, it’s been below single digits to below zero the last week, so you could say it was a beach day for me today 😎
