I have finally graduated and got a real job. This means I have the financial freedom I didn’t have as a college kid. I have dreamed of installing the mid arm for years and with kids in the horizon I want I get this on before I’m house and kid poor and fear it will never happen. My short arm lowers are a stock arm in the rear which is very bent and a rubicon express in the front which ripped off the lower bracket of my buddy’s jeep (I’ve added Currie mini skids in fear of them). I would like to finish the suspension but I still have the high antisquat and get hops on steep stuff. Enough that going to a place like Moab scares me just for that reason. So what better way to doing the lowers than to swap it to a mid arm.
The whole install seems simple. Cutting brackets as painful yet simple as they are don’t worry me. The brake lines will need some bending which I als plan on doing a bbk and re doing my whole rear brake set up so I’ll try and bent the lines for the mid arm when I install it. The exhaust will need to be re done which sucks bc I just had it done last year but it is a simple fix (re weld the cat and muffler farther forward) especially if i axle dump it since nh now doesn’t have inspection and I can’t imagine anyone ever caring. Plus with the plan of Ls swapping I’ll need to redo the exhaust yet again and will hopefully get it out the back.
My worry is the bulk head fittings for my arb lines. I think my front fitting might be able to stay in the same location. The rear will likely have to move. Can anyone give a good guess based on your savvy truss if these will work? I haven’t seen anyone say how they plug the old ones once moved.
