Harbor Freight tail lights on a TJ?
Yes, they're generic an they should fit just fine. All you'll have to do is wire them up.
Not sure how much you can trust this, but someone in the reviews said they installed them on a TJ. Looks like they should work, def not the same quality as the Black Magic lights. Harbor Freight is the type of store I go to for tools if I need a cheap wrench I can cut in half to make a specialty tool. :LOL:
Those HF lights look like the generic Chinesium available everywhere. If they are, give them a pass. I have them (generic) on my utility trailer and they're not particularly bright. Plug some LED bulbs into your stock housings, change the flasher relay and you'd be better off.
Yea need something soon. My current housing the bulb socket is broken. Either go with Amazon or harbor freight for now…
Well his current socket is broken, so he needs the entire assembly. I'd get the Hobo Freight lights, (they're cheap enough that if you don't like them, they're easily enough replaced), and put decent bulbs in them, whether LED or otherwise.
You can't change the "bulb" in the generics - I'm assuming the HFs are the same...
Here's a couple of pix of one opened up:
EDIT: Took another look at the HF lites - although very similar to the generics, they *are* different, thus MAY be mo' bettah! Or not...
Reactions: Oneslowtj
If you want some stock taillights (plug & play), I have a set you can have for shipping costs. I'm in Charlottesville Va. I removed them to install the BMB lights.
I appreciate the offer but I found a set at my local junkyard yesterday.
Did not realize that. I presumed that they had conventional bulbs in them.
Reactions: Zorba
I also have a set,but I would advise to go with led for the brightness,I almost had a lady run into the back with the dim ass oem trailer units🤣
Reactions: TheBoogieman
