Front diff bearing oddness, run it or replace it?
From what I can see I didn't have a problem with the pattern at all. The drive side is what we need to focus on and it wiped all the paint off the tooth. I thinks it's good to go 👍.
You might have been able to get away with yellow mustard for this one time. The problem is when your gears heat up it'll smell like hotdogs all the time 😂.
Wonder-Bar - and I thank you Sir! {BOW HERE}
Reactions: Zorba
Let’s get a test drive!
At my working pace, its gonna be a bit yet. Sunday, I hope to get the axle shafts back in and do the prelim static test of the locker according to their procedure. Then I can button that up, and fill with oil. Then the brake calipers need to be changed and bolted on, blah, blah. Then install the new steering bits (ZJ upgrade), and off to get it aligned. Then I'll take it to a nearby dirt road first.
Getting things put back together. 150 Ft-lbs on the nuts at the moment. Gonna go to O'Reillys and borrow their 250 ft-lb torque wrench to get it to 175 - mine only goes to 150.
Attempted to do the static test on the locker. Once side worked, the other didn't. Hit the web, read about someone having the exact same issue calling PowerTrax who told them it was just tight because it was new, run it and it'll be fine. They did and it was fine. So that's what I'm gonna do unless someone has a better idea.
if you gave it everything that lever arm had, it'll be fine. A million Oklahoma rednecks have sent it on far less torque.
Reactions: Zorba
Yea, I kinda figured that. What I'm gonna do is borrow their torque wrench (its free), and set it to 175, and see what the rotational distance is. I bet its less than a quarter turn. Then I'll know.
If you're at 150 now, I bet 175 will be less than an 1/8" more rotation. Let us know
Reactions: Zorba and ColoJeep
I'll take Mac at meaning 3/16 of a rotation so he's in the competition. Anyone in for 1/16?
Winner gets a free lap dance from Zorba! In a mini... ;) :D :D :D
Reactions: macleanflood
Have you been spending , too much time in the sun again . :LOL:
Reactions: Zorba
And.... the results are in!
Drumroll please....
@hosejockey61 Wins the GRAND PRIZE!! *da-bump, crash!*
It was at, or a bit less than 1/8th of a turn.
Of course the loaner torque wrench hadn't been run down to zero by the last moron to use it...
Now I gotta walk down to Ace - I put all new hardware on, but neglected to buy cotter pins.
Drumroll please....
Did he win a belly dance video?
