At least I don't have a female in my life who will tell me not to do this stuff lmao
That is the reason you can afford the Jeep!
That is the reason you can afford the Jeep!![]()
Jokes aside, I wouldn't spend that kind of money for stock location shocks.
An outboarded rear setup gets your shock closer to the forces at the tire for better leverage, and a longer quality tunable shock allows for a quality tune to provide better handling and ride quality. Similar idea up front using a shock tower that allows for a longer tunable shock.
As much fun as I have had with this thread it might end up costing me a few dollars as my current set up sucks, specifically on road. On road manners are more important to me than crawling
My expertise in suspension comes from the two wheeled world, I've never tackled the jeep seriously but know that what we do to the rear affects the front but in the jeep I am crawling, not trying to clear the hoops at speed. On road manners are more important to me than crawling at 5mph.
If I install the outboard shocks on the rear, will I regret not modifying the front?
how much work is that?
So where do you think the cut off for lift/tires is that still allows for an acceptable highway speed for a decent amount of time (say 1-2 hours)?
A lift just makes it harder, take longer, and you wind up with a lesser dialed in mounting location. I've done 100's of outboard jobs, I've never used a lift. The work always comes out much better when you can actually jack the axles up against a chained down chassis.After a bit of research there's no way I'm outboarding the shocks on my jeep. I'm not interested in cutting the frame and welding the back in, that's way too much work for me. Plus, I don't have access to a lift and don't have enough confidence in my welding skills for a trick like that.
I have a skewed understanding of skill since what I often find easy for me seems to confound others. I would generally say with a tutor helping who has some experience, it would be very doable. There is a build thread where the gent was doing this and while it was clear there was some good skills in play, the understanding of how to get from point A to point B needed some refinement. That did happen and it came out pretty good.Thanks... I guess that's what assuming does. What is the level of skill required to do something like this?
Do you have anyone that could help?I have a titanium Mig 140 from HF, only ran it gasless. Never welded anything this structural before.
I think the most in depth project I've done so far is replace an AX15.I have a skewed understanding of skill since what I often find easy for me seems to confound others. I would generally say with a tutor helping who has some experience, it would be very doable. There is a build thread where the gent was doing this and while it was clear there was some good skills in play, the understanding of how to get from point A to point B needed some refinement. That did happen and it came out pretty good.
We have a couple fab guys here, and I could probably get away with using the shop welderDo you have anyone that could help?
We have a couple fab guys here, and I could probably get away with using the shop welder![]()
You also used your lift to hold the rear axle over your head while you tried to sledge it inward enough to get the clips off. Had you lowered it to knee level, just the weight of the sledge in a gentle arc would have delivered twice the impact with half of the effort. Kinda like watching your granny shower through the gap in the curtain, just because you can, doesn't necessarily mean you should.Well I cheated and used the lift to raise the tub up a bit to make welding easier.
Which could have been done with a floor jack or my hi lift.
