Can outboard shocks and antirock sway bar exist together on the rear axle?
That's kinda what I was picturing as a possibility.
Do you have a picture of the brackets on the axle?
Are you keeping the fuel tank in the factory location?
Yes and I already have the anti-rock installed in the rear position per install instructions.
I'm not familiar with the install instructions.
A good reason to mount the AR in front of the rear axle is so that you won't have to fit the arms over both the coils and the shocks. It also helps to install the AR after the outboard once the coils and shocks are in place. Another reason to go in front is because the fuel tank limits where you can put it, especially if it has been raised up.
When I installed the AR I hadn't really thought about outboarding. Now that I'm looking at it there doesn't seem to be enough clearance for the AR to coexist back there.
Don't let the wheel spacer fool you, he's running Moab wheels.When I installed the AR I hadn't really thought about outboarding. Now that I'm looking at it there doesn't seem to be enough clearance for the AR to coexist back there.
Sometimes it is worth starting from scratch in order to get the best results.
I had to tweak my arms a little bit to clear everything once I was cycling my suspension.
I think you'll end up moving it to the front of the axle. But I think I've seen posts with it behind the axle too.... But my memory isn't always 100%...
