Coil springs bump stop
It's different. But the concepts are all the same as what is being discussed.
Can't be too much different? Try me, details? You have adjustable control arms? Anyways I read that since you rock crawl you could remove rear sway bar and disconnect the the front end links for more flex. Maybe you tucked the transmission or have a cover over it or cover over the gas tank?
Look for my build thread. I have sway bars both front and rear and I don't disconnect either while crawling rocks. :)
It took a lot of work to get my rear wheel to kick out like this.
