Going to be outboarding the rear shocks and relocating the upper spring perch brackets using the GenRight parts.
I realize I'm going to have to get new springs for the rear after relocating the spring perches, only because it's going to lift the vehicle even more so in the rear. With 4" springs currently, I'm thinking I'll likely need some 2" OME springs for the rear, since even as my TJ sits now, the rear is a good 1" higher as it is, and that's with stock spring perches.
Thoughts on this?
As for the outboarded rear shocks, I'm not sure if Rancho makes a RS5000X that will fit. What rear shocks are you using with your outboard setup @jjvw?
I have Fox 2.0 RR with 12" travel. If you do this, you want to put in the most travel that you can fit. And whatever shock you use for this will be the one you want to live with for a long time. The ultimate goal is to build in as much up travel as you can by reducing the amount of bump stop extension required for the compressed shocks, along with anything else that is in the way.
You can move the rear spring seats without changing the ride height. In fact. I lost over an inch after trimming the uppers to fit tighter to the frame and also flattening the lowers. This is one reason why I can run the longer Currie LJ springs.
Run the longest spring that gives you your desired ride height. Match the shock travel to the spring travel between full bump and the spring's free length.
Then there is the Rubicon problem. Pay very close attention to the rear driveshaft at droop. With short arms, it will bind sooner than other TJs. Either limit the down travel of the shocks, or run a center limiting strap above the diff to allow for more flex.
I used the Poly Performance towers and copied how Blaine does it.
