So it will never pop off at full flex?...
Can't say that it won't. If the extended length of the shock is longer than the free length of the spring, then the spring can fall out.
It would be good to know if this is a something to be aware of. It might not be. Are the springs loose when the axle is hanging by the shocks?I guess I won’t be disconnecting then[emoji23].
I wonder if there is a dropped pitman arm. Your Jeep probably isn't as stock as you think it is. Post pictures and we can help sort things out.Yeah, the pitman arm caused the problem. I have the shock back in and the front tires back on, but that was a concern for me.
Everything shown looks stock. How much spring lift?
Tire size? Any bump stop extension?
I don't see why you shouldn't be able to trim the spring mounts.
I don't understand why the steering would keep the axle from reaching full bump both sides.
In the last two photos (of post #2) it looks like you have some aftermarket control arms.
