What are bumpstops and what do they do?
Rook
Kent, WA
Clank! ... if that sound is coming from your suspension, that's not a good thing. If you just bottomed your springs and heard that metallic clank, it probably means you banged metal on metal and are at risk of bending or breaking some part of your suspension. And that means you probably need a reminder on the value of bump stops. Let's take a look at the function of a bump stop and some of the various applications for them.
The main purpose of a bump stop is to serve as some final suspension cushion to keep the metal parts from coming together or from traveling too far, which might in some way damage the suspension or chassis. In the case of a coil-sprung suspension, you'll want the bump stop to stop movement before a condition know as "coil bind," in which the coil spring is completely collapsed and can compress no further.
This is a good time to have some kind of effective bump-stop action at the front axle. There's a lot of motor weight bearing down on the front end, and if the suspension bottoms too violently, something is bound to break sooner or later.
Consider also that a bump stop used in the final bit of travel in a suspension behaves much like a variable (or rising rate) spring. This allows a vehicle to use a softer spring rate than would normally be needed if there were no bump-stop control. Using a bump stop allows the suspension to soak up large bumps while still allowing use of that soft spring for normal suspension travel conditions.
There are several types of bump stops and we'll discuss each in some detail here. We'll consider fixed-element stops and valved stops that use a compressed-gas cylinder.
Rubber & Urethane Bump Stops
The most common type of bump stop found on production vehicles is that of the rubber variety. These are simple to employ and low in cost. A common aftermarket step up from rubber stops are those made from urethane.
Both of these varieties supplement the final portion of spring travel with a high rate spring constant inherent to the bump stop. Additionally, their tapered shape provides somewhat of a progressive increase in spring rate as the bump stop is compressed.
Once you bottom the suspension completely, further force will be transmitted to the tire and other vehicle components until the bottoming forces are dissipated. Here, this Jeep lands hard on the front axle, collapsing the front tires to absorb the impact.At some point the downward force starts to transmit into compression of the tire carcass itself, or in an even worse case can fracture a wheel or other part.
One downside to a rubber or urethane bump stop is that they dissipate energy into the suspension rebound, which can cause your shocks to work harder. These bumps offer little damping and often behave much like a pure coil spring.
Urethane offers benefits in that it is easy to form and can be shaped with common machining processes. One downside to the material is that its durability can sometimes suffer as the urethane can begin to tear apart if it is compressed with excessive force.
Some newer model trucks use micro-cellular urethane bumps which can be recognized by their yellowish color. This type of material does offer some minimal damping affect as the material is compressed and then released under rebound. It also offers improved durability over basic urethane.
All fixed bump stops are designed to be short and come into effect late in the final distance of suspension travel. As such, they have a drastically increasing compression rate. That is to say that they stop the suspension movement very quickly and typically in a harsh manner.
Nitrogen Bump Stops
One form of stop that's become much more popular in recent years has been the gas pressurized nitrogen bump stop (often called air bumps or hydraulic bump stops). These cylindrical units consist of a short stroke shock mechanism that is velocity sensitive. Oil is used inside and moves through orifices much like a standard shock. This allows the bump to effectively dampen, or slow, the suspension movement through its final inches of travel. In contrast with an air or gas shock, they have large shaft diameters and are much shorter. Air bumps also exhibit some rebound dampening as well.
We consulted with Mike Labbe from Light Racing about the use of hydraulic bump stops. As mentioned, a suspension using air bumps can often run a softer spring rate so the ride is smoother under normal driving conditions. The air bumps provide the progressive end of travel function to supplement the spring rate of the suspension. A suspension that uses a fixed bump often becomes much stiffer earlier in the travel cycle to reduce the chance of a hard bottoming on the rubber or urethane bump stop. As of late, several OEM car manufacturers are exploring the idea of adding hydraulic bumps to allow them to run softer primary suspension spring rates for improved on-road ride quality.
Air bump reliability has increased in recent years with improved materials, seals and surface finishes to help prevent leaks that can quickly disable their function. Stop ends are typically made from aluminum or nylon, and longer travel air bumps can sometimes be converted to shorter travel versions with the addition of an internal spacer to reduce the expanded length.
Dirt-bike riders talk of a condition called suspension packing, where the rebound dampening has been set to high. As the vehicle hits successive bumps, the too-slow rebound keeps the shock from expanding before the next bump compresses the shock further. As a result, the suspension height drops with each successive rapid bump. A bump shock should ideally be set to lag the rebound speed of the suspension but not much slower than that rate.
Reactions: derekmac
Thank you for mentioning this subject.
for my 2002 TJ bought less than a year ago, I noticed that the former owner had installed Spring Spacers 3 "at the front and 1.5" at the back.(like in the pictures )
I also noticed that the Bumpstops are damaged in the front (probably the cause of an old accident). so I wanted to know if it could cause me problems or damage the car since I rarely do track rides (especially beach sand) ...?can a damaged bumpstops damage the car when used in roads and highways ...?
I also have the impression that the car moves a lot to the right and left especially when the road is not flat and when there are curves ... can this be explained by damaged Bumpstops? or is it the sping spacers that are responsible ...?
for my 2002 TJ bought less than a year ago, I noticed that the former owner had installed Spring Spacers 3 "at the front and 1.5" at the back.(like in the pictures )View attachment 66727View attachment 66726I also noticed that the Bumpstops are damaged in the front (probably the cause of an old accident). so I wanted to know if it could cause me problems or damage the car since I rarely do track rides (especially beach sand) ...?can a damaged bumpstops damage the car when used in roads and highways ...?
You have issues largely separate from what this thread is about. Whoever installed the spacers do not reinstall the factory bump stop cups. That is a problem on any suspension setup. The body roll you are experiencing is likely shock related, worn shock/sway bar bushings, or missing sway bars.
Post this in the general section and we will help figure things out.
Check out that rear. I'll bet that up-travel is painful!
@Chris if I want to lift my Jeep 2.5 inches, what size bump stops do I need? And can you recommend me a lift kit that has everything I need, or can you tell me everything I need to do, because I’m new to all this. I just got my first Jeep a month ago. It’s a 2004 wrangler Sahara. Thanks! :)
Reactions: Fixer6
No one can give you a 100% concrete answer on that... no one.
The ONLY way for you to determine the length your bump stops need to be is to cycle the suspension. If you don't know what that is, check out this thread by @fuse: Bump Stop Check Walk-Thru with Pics.
While we could give you our best guess for bump stop length, there are too many variables that differ from vehicle-to-vehicle such as actual tire size, stock or aftermarket fenders, which track bar you have, etc. Basically it really does vary from vehicle-to-vehicle.
The most popular 2.5" lift I can recommend is the OME 2.5" suspension lift:
https://www.amazon.com/dp/B004P9JY0E/?tag=wranglerorg-20
That lift is very highly regarded as the best 2.5" lift "kit" on the market, and having run one personally, I would have to agree. It includes everything you need, including the proper bump stop for 31" tires (assuming you don't plan on running any bigger tires), stock fenders, and stock track bars. That kit includes everything you need, ready to install and go.
Like I said though, the limitation is 31" tires. You can run it with larger than 31" tires, but if you do, that's when you're going to need to cycle your suspension and additional bump stop beyond what is included in that kit.
Reactions: Pate15
Ok thank you so much this really helped me out! Bit can this lift kit work with 33” tires?
2.5" isn't really enough for 33" tires.
For instance, here's my 2005 Jeep Wrangler Rubicon with that same lift and 33" tires:
Notice how there isn't very much gap between the wheel and the fender? This is because 33" tires really require around 4" of lift to have the proper amount of wheel / fender clearance you want.
So, what's the solution? Fortunately it's cheap and easy!
Get a 1.25" body lift such as this one:
https://www.amazon.com/dp/B005TTZLE2/?tag=wranglerorg-20
That will put you at 3.75" of lift total, you'll have just the right amount of room for 33" tires, and in addition, you'll have a body lift, which sets you up for other mods down the road that require a body lift, such as a tummy tuck!
Reactions: fuse and Pate15
Oh wow that’s perfect because the previous owner put a 1.25 inch body lift on it. Also, would I have to do that rear axle drop at whatever that is?
Sounds like you’re all set up then!
You will need to install a transfer case drop, but that is included in the OME lift kit I linked to above.
